1 - 13 of 13 Posts
Hi all! Pretty much after I drove my 2018 Atlas SEL off the lot, I noticed a vibrating buzz from the upper left of the driver side door panel (see pic for area of the noise). It has gotten worse over time (now with 12K on the car). Every time you hit the smallest bump in the road it buzzes (the best way I can describe it). It is really bad when you are on road/highways where the road has that little bump every X number of yards and you constantly hear it in your left ear -- it really makes a great ride unenjoyable. It also does it if you turn up the stereo with lots of bass. I know it is the door/panel as when I put my arm on the armrest and push down hard, it will stop but only when doing so.
Had it to the dealer twice for other issues and told them to look for this noise. They said they hear nothing. So, what are my options? Is there a way for me to take off the interior door panel easily and see what is going on? Perhaps I can fix it with some tape or glue -- ha!
I have to say, overall, the Atlas has way more pops/creaks/rattles/buzzes, etc caused by interior plastics than any $40K+ car should have. There are many in this car, but the one I mention above bothers me most as it is right in your ear! I have a 2010 Mazda3 hatch and it has way less interior plastics noise than the new Atlas. I was thinking about replacing with a GTI at some point, but if all VWs are like this, I think I will pass.
Thanks in advance all. This is a great site!
Not sure what would be involved in opening up the door panel, but more soundproofing/insulation would go a long way in addressing this kind of problem. There are some good DIY videos up on youtube for fixing rattling on other VW models.
I own a 2018 Atlas SEL 4Motion Premium and have 3000 miles on it. Bought the vehicle in April 2019 new, and since I have another vehicle, I don't drive the Atlas much. I like the Atlas but this humming/vibration noise stretching my nerves and patience. I have noticed this humming and buzzing vibration noise coming out of the driver side door also pretty much the first week I had the vehicle, and like you said PacMan, it is very annoying and irritating, sounds like a bee or a metal-to-metal buzzing sound. Nevertheless, I took it to the dealer 3x already and the service manager drove it the 3rd time and he also heard the noise. They adjusted the door apparently, but that worked only for the time being I was drove home. The next morning went for a drive on the highway and the noise was back. After weeks of trying different things, I stuck a folded sheet of paper-towel between the door frame and the rubber seal of the door by the upper corner and that made the noise stop. Also noise coming out of the door panel (music is not on), an adding irritant to the humming noise. The humming/buzzing/vibration noise can only be heard from the driver seat and it is right in your ear! It is a safety issue as far as I am concerned as the noise can take the driver's attention off the road as being so irritating. I call it the "luxury" torture noise, cost: $50K! I have maintained email communication with the dealership and if they don't fix the noise, I'll file a claim.
Hi! Have any of you found a solution to this drivers door panel noise? I just bought an Atlas two months ago and I can barely stand the noise any longer. I have taken in to the dealer and they always state they don’t hear anything. Any feedback would be appreciated. Thank you!
Noise, rattles, etc. drive me crazy too! You might want to go to a body shop and have them refit the panel. It might cost you a few bucks, but they deal with this stuff everyday.
Dealerships are limited in what they can or are willing to do.
I think there was another thread about this, because I feel like I posted this already but....
While it may not be the case for you, sometimes it is in fact the rubber door seal that is making the noise.
It can sound like a rattle or buzz, but it is actually just the seal.
One way to figure that out is if it does it all the time, or just sometimes.
One way to try to fix it is by cleaning off the seal and your door jambs and buying a product called gummi pflege.
I have personally never used this, but it is something that comes up on the VW GTI forum I'm on as a solution to the noises.
For the record, both my Atlas and GTI driver doors make a intermittent buzzing/noise.
Mine say the same durn thing!! First dealership I took it in, I had two tires out of round, they said it was normal for the Atlas to rattle and brushed it off. Replaced tires, still rattles. Took to another dealership found the other two tires cupping, I purchased $1000 set of new Michelins.. hoping to fix the rattles, it's helped but STILL rattles on esp rough and still smooth drives. Three different rattle spots interior.. I'm about crazy dealing with VW. Corporate said can't do anything until dealership hears a rattle. I said the first dealership did and told me IT WAS NORMAL! ughhhhh!!!
They heard it on mine. Door panel sections are not tight. They solved that rattle.
Insist they go for a ride with you.
Sounds like you have been through your fair share of stress as well! After several trips to the dealer and a body shop the door panel noises have mostly been solved. According to the dealership, the noise was cause by some screws in the door panel (near the handle you use to pull the door shut) that needed some Loctite and tightened. I also had a whistling noise coming from my upper right drivers window. Supposedly some adjusting of the door fixed it. We will see.
1 - 13 of 13 Posts
