Just finished V1 hardwire install, tapped into Fuse #47, which is the rear wiper motor, works as desired, but I have the annoying engine start/stop reset, is there a different fuse option that will not be affected by the engine start/stop funciotn ?
Font Material property Parallel Pattern Paper
well, swapped for fuse #40, no dice on the stop/start function..case closed.
Why not use SC48? That's what I used for my Uniden R7. Shuts off when you turn off the car. Turns on when you start. Going to tap my dash cam into also. It can handle the load. Just pointing it out.. I had the same issue. Though the diagram says it's not used, it just doesn't have a fuse in it, but has power when the car is in ops mode. Car shutting off (stop/start), doesn't affect it.
I tried SC48 but didn't get any power out of it, will try again, also what did you use for ground ? used the top right bolt, but found a better one on the left after remove the trim cap......
