1 - 10 of 10 Posts
2019 VW Atlas SE 4 Motion w/ Technology
Does anyone have an guidance on whether it is allowed to 'flip' the hitch to get a higher rise on the trailer ball? The standard hitch drop with 2" ball only gets to approx. 19" above the level pavement. Most of the travel trailers I am seeing are on the order of 22" or more inches. The etched placard next to the hitch and the owner's manual seems to indicate it should only be used in the 'drop' position. However, it doesn't specifically exclude it. I'm worried that with the ball above the receiver, there's going to be additional torque on the receiver assembly.
I wouldn't flip the hitch. You might potentially do damage to your vehicle if the trailer overshoots the ball. You might consider lifting the SUV
2019 VW ATLAS Highline
Most hitches are designed to be flipped. They have a ‘rise’ and a ‘drop’.
I have mine setup for 1” rise, and this was professionally setup.
The most important aspect is that the trailer tongue is level with the asphalt so tongue weight is correct.
Ball too low and undue suspension burden on your vehicle.
Ball too high and shifts the weight rearward on the trailer axle and difficult to control.
1269
1270
Ball too high and shifts the weight rearward on the trailer axle and difficult to control. View attachment 1269 View attachment 1270
What is the distance from the pin to your ball on that ball mount? Looks short, and I have been having a hard time finding shorter ones.
I decided to buy the VW Ball Mount, the MSRP price is $137 instead of the $30 you can get from CURT at any Advanced Auto Parts. On the VW the distance from the hole to the center of the ball is 6 1/2 as specified in the Atlas. I did it to be extra cautious, the longer will be more stress is put to the "super MQB" VW platform. Rode already 1,000 miles with no issues. Only the factory installed hitch and the CURT Echo bluetooth as brake controller. Towing an APEX Nano 194BHS and the combined weight (Atlas + people + tongue + trailer + cargo) is around 9,500 pounds.
I'm having a similar issue. I'd like to tow a Minnie Winnie but I'd need to raise the ball roughly 8" to keep the trailer level. I'm having a hard time making myself comfortable this can be done safely since the hitch specification shows it as a drop.
2246
Can you tell me the coupler height with trailer leveled? Planning to buy a 194 bhs.
Sorry it took 2 days to get you an answer. My '18 SEL-P (factory 2" receiver) measures 16" to the bottom of the square hole for the receiver. Therefore it is 18" to the top of the square hole for the receiver. Make sense? PM me if you need more info. Good luck.
I am not sure what atlas version is this, but on the exec line the manual says "the drop height of the ball can't more than 2 inches and the pin-to-ball must not be more than 8 1/4 inches. "
I was curious about the height part but after reading @EdmontonATLAS I would move to a higher hitchball as in my case, my trailer is offroad edition
1 - 10 of 10 Posts
