Does anyone use unleaded 88? I cant find anything from VW that says it is either safe to use or not safe. I can find information that says the minimum octane rating is 87 though.
Thoughts?
Thoughts?
Of course you have no issues, VW has tuned the engine to be able to run 87 as the min without issue. 40K/4 years on straight 87 for me with zero drama as would be expected. My graphs earlier in this thread show the difference - you want max performance, towing, mountains,etc.? Run higher octane fuel. Around town normal daily life? Save your money.I use 87 octane gas...no issues.
(2021 Atlas Cross Sport, 4-cyl)
I am not putting E-15 fuel in any car that does not say it is approved for use in the car.Does anyone use unleaded 88? I cant find anything from VW that says it is either safe to use or not safe. I can find information that says the minimum octane rating is 87 though.
Thoughts?
Check your owner's manual, E15 is perfectly fine/within the window of fuels that are ok to use.I am not putting E-15 fuel in any car that does not say it is approved for use in the car.
That is correct but you need to do the math on the cost difference - 5% E difference will be almost impreceiveable w/r to mpgs but will be cheaper per gallon so may or may not be a better deal..just need to calc it out....it's ~$0.40/gal less than 87/e10. You won't beat it with the slight drop in mpgs...There are plenty of videos out on the internet with evidence (not subjective) that more ethanol = fewer mpg and less power to your engine because there are fewer BTUs in ethanol than in gasoline. My own experience bears that out. Take an older car (pre-2007) and put pure, non-ethanol gas (which is available in some locales, mine included) and run on exclusively that mix a tank or two, and measure your average mpg. Then run 10% ethanol and be blow away by how much worse your fuel economy is. This is not rocket science. Just because more modern cars can adapt the timing and spark to run "efficiently" on ethanol blends doesn't mean you will get any more power out of it. It's just not there to begin with. I do not want to run "88" through my Atlas, even though it says it's okay to do so for that reason alone. 87 octane regular with 10% ethanol will get you more mpg than 88 octane 15% ethanol.
In my experience the drop is not slight. It is very perceivable. Do not want.That is correct but you need to do the math on the cost difference - 5% E difference will be almost impreceiveable w/r to mpgs but will be cheaper per gallon so may or may not be a better deal..just need to calc it out....it's ~$0.40/gal less than 87/e10. You won't beat it with the slight drop in mpgs...
5%? I run 25% in my Sportwagen and it's minor vs e10 93.In my experience the drop is not slight. It is very perceivable. Do not want.
