Hi all. New here, and proud new owner of a 2021 Atlas SE w/ Tech R Line. One of the things that attracted me to the vehicle was the styling. However, I was unaware that you do NOT get the double LED lined headlights until you get into the upper models. I ordered the car and was not able to notice it. I drove a SEL on the test drive. My question is as follows: is there anyway to “hack” or enable the double lines on a SE Model. Thanks all and happy to be part of this forum.
I believe you need to put SEL headlights in and the code with VCDS/OBDEleven it in order to get that look you are looking for.
Yeah as silly as it sounds I don't believe you can just turn it on. Like Tyler said, it is likely you need to replace the lights and do some "hacking" at that point.
I know this is the case for the MK7 Golfs as well. The Golf R has 2 led "U's" where the GTI only has 1.
2019 Volkswagen Atlas S AWD
Not sure this route would be viable anymore(at least for now). From what I’ve been reading, neither VCDS nor OBDEleven currently can write changes to the 2020+ model years, due to some new type of firewall that is implemented.
