If that's the case which I hope it is here then it might just be a case of running clay bar over the paint to remove those imperfections on the surface.Is it possible to post pictures of the rust/corrosion? Surface rust that gets stuck in the clear coat is common and can be easily seen on white/light colored vehicles. A lot of time this is just carbon material from brake dust or atmospheric corrosion.
I am thinking of buying an Atlas and noticed a used one at the dealership with many rust spots on the tailgate. When I asked if this issue was common I was told that they had never seen it before. I would like to save money in a used one if possible, so wondering how did your claim turn out? Do you have a picture?I found rust on my tailgate.. they replaced the tailgate and are on round 4 of painting it. Not sure what’s going on..lots of little spots that are not covering correctly.
