Remote start doesn't work, check engine illuminates only during the remote start attempt then disappears. Car can be started manually. No low gas light, no low fluids.
This is the second time this has happened, first time into the VW dealer they said it was a faulty fuel level sensor in tank. As per their documentation; Removal of fuel pump assembly, tested and replaced fuel level sensor, oring and hardware, reset readiness code.
It worked fine for about 2 weeks afterwards.
I'm assuming that their original fix was probably not the root cause and what probably corrected it for a short time was the reset of the readiness code, but since original diagnosis was possibly incorrect regarding the initial issue that was causing the CEL and the remote start malfunction I'm unsure what else could be causing it...
Any ideas?
Any ideas?
