Just completed my first towing trip with my VW Atlas Highline with R Line package here in Canada. Overall trip length was roughly 850 km /500 miles. Purchased a new Jayco X19h trailer, dry weight of 3877 lbs, 360lb tongue weight. I went for the weight distribution hitch set up, although VW doesn’t want you too.... without the equalizer set up, the Atlas squatted really low on the back end. On the trip was myself and my adult daughter, our food and supplies loaded in the trailer. We don’t pack too heavy, but had a fair amount for our 4 day trip. We took one of the famous highways in Canada with mountain passes that were in some cases a 7percent grade for 15 km or so . Obviously you do feel the resistance from the trailer behind you, but the Atlas felt very stable.
As far as power in the Atlas, it could always use more.....but that being said, once you learn to use the manual shift mode properly,you will find that the Atlas has a sweet spot when towing, which is @ 3000 rpm. I would shift in manual mode on the hills finding the gear that held it at 3000 rpm and it did well. On the steep grades the Atlas would hold 80km/h and on the flats, 100-110 km/h in regular sport. Ode @2500rpm or less. I really didn’t want to push the atlas too hard so tried to keep it in the under 3000 rpm range.... revving higher really didn’t add much to speed, but rather just dropped the fuel economy further. When tracking the fuel economy, it was not great by any means. Went through 2 full tanks and a bit on the journey. I probably picked the hardest pulling highway , Hwy5 Coquihalla Hwy ..
I would definitely not pull anything heavier with the Atlas, lighter would obviously be better. I will rarely do that highway, so to me I a, more than happy with the way the Atlas pulls, and the comfort you get to ride in doing it... overall I would say the Atlas is a great choice if you keep the weight down....
