Got 'er done. For other d-i-y ers......
1. trans. pan has a drain/add hole and, within it, a 5mm plastic socket head "level plug"(actually a threaded tube-open at both ends. Level plug installs on top of drain plug inside the pan.
2. To drain the pan- remove both plugs w/ 5 mm allen wrench.
3. Capture the drained fluid in order to accurately determine the amount of new fluid to add.
4.Buy an inexpensive hand operated fluid pump with clear hose.
5. " a 1/8 x 2 1/2 copper nipple
6. saw off one of the threaded ends of the nipple & cut 10m x 1 threads on this end(to match the trans pan threads)
7. Screw the "original threaded end of the nipple into the pump tubing.
8.Get 3 liters of ATF(Pentosin 1 LV) Advance Auto Parts has it.
9. Re-install the "Level Plug"(don't over-tighten)
10.thread the prepared copper tube into the drain hole & pump away.
11. When the proper amount of ATF has been filled-the fluid should flow down the level tube and serve notice.
/or you fill the amount you drained.
12.Be quick in removing the brass tube/ re-install the drain plug.
