Does the dealer need to code the key fob.It doesn't work with the fob...works with the door handle (where you touch to unlock/lock). Need to use VCDS/OBDEleven to "code" the key fob to do that.
This is a DIY thing, you have to buy one of the scan tools I listed. It's a bit more invovled that you likely think. You can certainly try to ask the dealer and you may find they will do it...not sure. It's coding the vehicle itself so that the keyfob will do this. V. common in the VW world for years to do this mod with VCDS or OBDEleven (I believe Carista will do it as well). Good luck. You can google "OBDEleven windows down with remote" or similar to start the learning process.Does the dealer need to code the key fob.
I see others have answered but I'll chime in to. Long story short, VW did not program the ability to close your windows w/o a human being there at the car. There is this thing called "the pinch factor". The car has a rain sensor and I found out when I owned my 2013 Passat that that feature was turned off. Reason? If you had the windows down a bit and lets say it's not a hot day and you left fido in the car, or god forbid a kid, and they had their head out the window when it started to rain, it could choke them to death. But turning it on, turned off the windows ability to detect blockage and would put enough force on closing that it could kill an animal or small kid. Now, I'm going to guess that still applies. If you program it to close with a fob is one thing and can't answer if it will stop movement if it's blocked. But "rumor" had it that you could hold the unlock/lock part of the door handle to close the windows, but not open them up, without owner programing. Not trying to discourage you but you might want to ensure once you program it, that it will still stop if there is a hand, arm, neck or small animal in the way. Anyone have any additional info on that?I have the window convenience on all windows, in the settings but when I press and hold the unlock it doesn’t open the windows.
Am I missing something?
I have a 2019 Atlas SE 4 motion/ R-Line with Tech package if that helps.
This is from VW online manual:I have the window convenience on all windows, in the settings but when I press and hold the unlock it doesn’t open the windows.
HOLD THE BUTTON DOWN, 2019 SE w/TechI have the window convenience on all windows, in the settings but when I press and hold the unlock it doesn’t open the windows.
HOLD FINGER on the OUTSIDE LOCK INDENTATION ON DOOR HANDLE, 2019 SE w/TechI have the window convenience on all windows, in the settings but when I press and hold the unlock it doesn’t open the windows.
