Ha I’m no master, but thank you. It’s not a huge movement, but it can vary based upon your height. It moves pretty decently for me since I’m as some would jokingly say I’m vertically challenged.
I drive really close to the steering and Im 5’9. Easy exit only moove 2/3 inches. I still can manually push the seat back 7/8” more than the easy exit. So I was wondering if maybe there’s a sequence I need to do to “set” where the easy exit seat would go?Ha I’m no master, but thank you. It’s not a huge movement, but it can vary based upon your height. It moves pretty decently for me since I’m as some would jokingly say I’m vertically challenged.
Did you do the auto/start stop voltage change? Tried it on mine and it shows the value I entered correctly, but it does not turn off and first stop I make the car shuts off. The Urban Joke version 1 tails work perfectly though so it isn't just my obdeleven not working. I had the hood open when I made the changes. Also couldn't turn off the no menu access when moving even though it shows everything not activated.For those who were wondering how work the OBDEleven with the 2022 Atlas: flawless!
I use the ios version, and all coding worked first shot. Hood open is the key. Just need to pop the hood, no need to fully open.
Good stuff, just ordered one. Thank you. I'll have to keep my eyes out for any other 2022 updates.If you have the newer models like 2021/22 you need a hardware defeat for start/stop. B2BFab sells one.
Module 03 Brakes (ABS)Anyone have the longcoding for byte 29 to set the ESC/ASR options so ESC can be off?
I`m not so sure about the first one.Is there any coding for these mods?
- Make the 360 view the default camera for reverse
- Change the fuel tank size so the low fuel light comes later
Also, I have enabled the watch movie while in motion. But how do we watch movie? Does it need to be on a usb-c stick? Does it start automatically, or it needs to be on MEDIA?
Here is my latest/greatest. Spreadsheet is the list of mods with a description, .txt file is the instructions/coding. All of these are tested/proved out on my 2018 SEL; dubtle changes year to year can cause issues/changes in these so b/c it works on mine, it may not work on your newer model. You have to have the hardware to male things work i.e. you can't code auto folding mirrors if you don't have mirrors that auto fold (duh). Finally, most of these are consistent across VW's MQB platform vehicles so I have an '18 Golf, most of these work on it as well.
If you don't know what OBDEleven is, please google it/youtube it/FB it, etc - tons of info out there.
TLDR: a dongle/app that goes in your OBDII port that allows you to scan, log data, and make all sorts of changes to your VW/Atlas. No, it doesn't "void" your warranty but as always, you are on your own with DIY and I'm not responsible for your goof-ups. If you screw up your car and take it to the dealer, expect to pay their labor to fix it. End.
OBDEleven_mods_Atlas_June_2020.xlsx
drive.google.com
OBDEleven_mods_master_list_Feb_2023.txt
drive.google.com
Hello there,Here is my latest/greatest. Spreadsheet is the list of mods with a description, .txt file is the instructions/coding. All of these are tested/proved out on my 2018 SEL; dubtle changes year to year can cause issues/changes in these so b/c it works on mine, it may not work on your newer model. You have to have the hardware to male things work i.e. you can't code auto folding mirrors if you don't have mirrors that auto fold (duh). Finally, most of these are consistent across VW's MQB platform vehicles so I have an '18 Golf, most of these work on it as well.
drive.google.com
drive.google.com
I have anew 2023 Atlas and is this OBDeleven worth it? can I change any other temperature controls for the auto start fuction? easy entry?For those who were wondering how work the OBDEleven with the 2022 Atlas: flawless! I use the ios version, and all coding worked first shot. Hood open is the key. Just need to pop the hood, no need to fully open.
Hey ...I know this is an older comment but wondered if/what the dealership did when you say they did it incorrectly? I just had them do encoding for a new battery that was already installed and they apparently didn't even pull it out to look at it. My understanding was/is that there are specs on it that should be included during the process? At the very least, they should have noticed that the auto parts store gave me a standard flooded battery vs. the EFB+. Went back, got an AGM and dealership did a courtesy recode, but given what happened the first time, I'm dubious as to whether they have configured everything right.I'm new here. The battery on my Atlas tested defective at the dealer 6 days out of warranty and they wouldn't take care of it for me. I replaced the battery with an after market AGM. I'm trying to avoid dealer fees for registration and recoding. Does anyone know if I can do the recoding with OBDeleven?
EDIT
I was able to do battery coding and adaptation on my Atlas with OBDeleven. I took it to a VW auto shop and they did it incorrectly. Here is video of the steps:
Yep. Getting it to return is the issue. If your Atlas doesn't have the memory module for it (which it almost for sure doesn't) then it won't work correctly.Is there anyway to make the passenger side mirror tilt down when backing up? My Audi used to do this with a vcds tweak
