The drive setting button doesn’t light up so I can’t tell which setting I am currently using. Is this a fuse replacement issue and fix? Thanks
Is that the only light that is out? If you click or rotate the knob for the drive setting does it change on the front screen?
No it doesn’t do anything and from what I’ve read it should light up. As far as I know it’s the only light that’s out
You can check the fuses. I would think there would be a code being thrown though if the awd system wasn't functioning.
Fuse diagram and list posted here. You have to go to page 2.
Thats surprising that a fuse would blow for that one and the reason why I asked if anything is out is because usually they tie in multiple lights to one fuse since they don't draw that much power. Hopefully its just the fuse and nothing else; when I went through the manual I did not see any diagram for the fuse box.
