I don't mind it but my wife doesn't care for the feature..Can it be turned off permanently in the Atlas?
There shouldn't be any indicators in the dash from that tweak from my understanding.and unlike the solution to change the voltage in the setting this option hopefully works without any indicators on the dash
yes that does workHere is something that I learned that may solve this issue (even though I have not personally tried it my self.)
I was at the dealer this past weekend to test drive an Atlas and this topic came up. The VW agent told me that he read that when towing with the Atlas, the Auto Start/off is automatically disabled.
So his suggestion is if you can connect something to the tow connection (maybe one of those stop lights) to trick the Atlas to think you are towing, this may be a way to permanently disable this feature.
Can some one verify that this works?
Does this work?With OBDEleven:
1) Select Control unit 19
2) Select Adaptation
3) Select Stop start limit voltage
4) Change value to 12 (default is 7.6)
