Hi I own 2019 4mo 3.6.
I think about installing a lift kit to get it higher.
Does anybody did that and if yes can I get an answer for two questions:
1. What kit should I buy?
2. Is there anything else I should install to avoid problems with suspension elements degreeses and geometry problems?
thanks
thanks
Smith VW has a decent kit, based on Atlas geometry.
You can either do 1) spacers or 2) new coil springs. I vote for the H&R lift springs personally but the spacers are cheap and effective. Either is a v. mild change and will work within your current suspension geometry. Always get an alignment after modifying your suspension (raise or lower).
