Going to be towing, and will be getting a brake controller. Currently have comfortline v6 awd with the package.
For the controller do I have to just get the module, or do I have to get the wiring harness as well. I heard the tow package has the wiring already done.
Any thoughts or insights (especially install tips) are appreciated. I heard it's not that bad for a diy task. Thanks Chris
Just a couple of quick things to add beyond what
@sidewinder has already provided. I know you're only asking about the brake controller, but in case you haven't read about it elsewhere, VW for some reason doesn't provide the last connector at the hitch that's needed to connect a 7-pin trailer hookup. You can get the part you need from your dealer or get this version from Amazon for $20 --
https://www.amazon.com/gp/product/B00AO71OJ0/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1. I wouldn't be surprised if it's the exact same part, and it works perfectly. It takes 2 minutes to install.
Regarding brake controller options, I went with a Curt Spectrum, as I liked the very small size and the ability to keep the accelerometer module under the dash with only a small control knob double sided taped near my instrument panel -- no drilled holes. I installed it myself buying a connector harness, to connect from the Atlas to the controller, from the seller
@sidewinder mentions on Ebay (
VW Atlas Plug and Play CURT Trailer Brake Control Harness | eBay).
Regarding the install, if you watch the videos and learn the tricks of getting the various trim pieces off to fetch the Atlas cable, it's not too bad to do. That said, if I were doing it all over, I would likely bypass all the wiring and go with a bluetooth controller -- the Curt Echo. Lots of good reviews on the Echo, the ability to monitor things on your phone, and much easier installation.
