Hello! This is not your typical battery post! (I know, I searched!) I know you have to code them (although I didn't and it is fine so far).
Really, I have a question about battery size. I have an SEL Premium and had the battery fail after 75k miles on the car (not bad!) I went down to Walmart and bought a suitable replacement (H6 AGM) even though their system first recommended an H5 - it seemed too small. Turns out we were right - the existing one was, in fact, an H6.
Well, when I went in to change it, I noticed that the battery tray has an additional bracket location (bolt hole) that would accommodate a longer battery than the H6 - had I know this, I would have probably spent the extra $0 and gotten an H7 (assuming it is that and not an H8). The extra 4 lbs. wouldn't bother me too much, either.
Has anyone put an H7 (or H8?) into the car? Does it fit OK otherwise? Any other insight? Is it possible to overstress the alternator? Thought it wouldn't hurt to throw up a thread as others might find this info helpful.
Thanks!
Thanks!
