1 - 20 of 20 Posts
At this you point we have a noise that happens only under specific conditions (third gear slow-starts near 1K rpms) that sounds like a pump cavitation due to the TCU mapping not downshifting to second. This has been around since the Atlas was released and they all do it just some louder than others. They replaced your t-converter and it didn't do a thing - I have read of another owner that had his t-converter replaced with the same results.
So what do you suggest a fix to this is? I'm curious. You're throwing some jargon here like pump cavitation due to TCU mapping blah blah...are you suggesting this is acceptable? And what good is saying what the issue is without proposing a solution?
The noise is horrible and should not exist regardless of what the reasoning is. Even if exists in many Atlas vehicles or let's say all of them for example...that doesn't deem it normal. That to me deems it as an issue that should be fixed/resolved.
How do you know there is anything actually wrong? There is no solution...this is per design based on all of the research I've done so either 1) accept this noise the few times a day it happens or 2) loose however much time of your life chasing it with VW to hear that you will end up at 1 unless you sell it. I have chosen 1 and moved on.
The transmission only makes this noise in a v. tight set of conditions; slow to a near-stop, transmission stays in third gear, you accelerate from ~1K rpm....it's just the shift point mapping. If it dropped to second (which you can do manually), you will never hear it. I get the concern, but this has been beaten to death on every internet sit related the Atlas and exactly zero people have had a fix so this leads me to my first comments in this post.
Good luck!
Does this noise last for more than a few seconds? What about when accelerating moderately from a stop?
Yes, until it reaches (I seem to recall) ~1.8 RPM then it will abruptly stop (the description in the videos I posted may address that). It will always do it under these conditions; the more strongly you accelerate the faster you reach the RPM cut-off where it stops if that makes sense. Bottom line: starting near 1K RPM in 3rd gear will create this noise 100% of the time.
I bought 2018 Atlas almost two years ago. In last winter, I started hearing the rattling noise when accelerating from low RPM (1000-ish rpm) and even worse when made turning. I brought it to the dealership for the investigation, after test drive with their senior mechanic, he said "heating shell is shifted somehow" confidently. So they spent two hours to re-position the shell (I don't know what they really did on my Atlas, at least that is what I was told and mentioned in service report). The noise has gone since. But unfortunately, the turning rattling noise is coming back recently. Not sure it is caused by the shell shifting again or some other reasons you guys talking about. Anyway, I will let them check it again during the next scheduled maintenance which is probably one month later.
That is most likely not the same issue we are discussing here.
Thanks hydroatlas for posting your thread. Thanks to all who are posting on this issue.
From senior to junior members, and Atlas Guests, if you are experiencing this noise, the point is, THIS IS AN ISSUE!! Any way you look at it, this is an engineering fail - albeit may not be causing any mechanical issues, or is it? That should be everyone's concern - owners, dealers, and manufacturer because everyone has something at risk here regardless of the annoyance factor. I personally love my Atlas, and have been drivign in manual mode to get around this - BUT WHY SHOULD I HAVE TO?? Sorry I'm yelling at VW not you the reader :)
So keep posting until VW takes notice and fixes it. The more posts - the more people will know. I've decided to take it to the dealer to get a "Customer Concern" service record on record, suggest all do the same.
VW - If its as simple as a software update, then just do it. Start listening, and then start talking to your customer base!
2019 Atlas SEL 4-motion w/Tech
I have a 2019 Atlas SEL 4 motion with 2400 miles on it and this was noticeable from Day 2 after I bought the vehicle. The dealer is asking for a 2.5 hour “diagnostic fee” to trouble shoot the issue. Shouldn’t whatever it is be covered under warranty? I can duplicate the issue by putting my foot on the brake, put it in gear and maintain 1000 to 1500 rpm.
'19 Atlas SE R-Line
Does it make the noise if you keep it in 'S' instead of 'D'? (Just got my Atlas so I get to ask these newbie questions :p )
It happens in S or D. It's all about 3rd gear at a low RPM. Not sure if you can force it in manual mode by shifting to 3 and revving to the right RPM....haven't tried that.
Don't waste your time. VW knows all about it and has no plans to address the sound. They say it is normal at those conditions.
'19 Atlas SE R-Line
So we're talking about a noise that is made under certain circumstances that is not causing any damage, and is not operating in an non-normal manner? I don't know about you, but I'd just turn the music up louder, or put on some heavier metal music. Or both
Reactions: KarstGeo
VW Dealer Diagnosis: Noise is "Considered Normal". How can this be "normal" for a new car? Dealer says they tried another Atlas on the lot and it was doing the same thing. BUYER BEWARE! - Be sure to check this out on your new car before buying an ATLAS.
1146
'19 Atlas SE R-Line
Again, the fix for the torque converter 'sound' is cranking up the stereo. I'd recommend a little Slipknot:
I have a 2019 SEL R Line V-6 and it started happening 3 weeks after I purchased it NEW. I first got a runaround, then after several more visits and a few derogatory comments on their FB page I got a call from customer service, they appeased me with a "ride along" and the Service Manager said " I don't even need to ride along, I have at least 5 complaints a week about the same issue- it's normal" Same story all around town. For a $45K SUV, it shouldn't sound like an 80's oldsmobile with transmission squeal- So very disappointed in my purchase. Seems to me if its a mapping issue with the transmission, they should have an easy fix- always makes the noise in 3rd gear. At the point of trading it in because I can not unhear it- poor customer service. I will bad mouth VW until they fix mine or I sell it.
Hi All, well 2 years, 27k miles, screaming banshie torque converter (or whatever), and now a slipping tranny, and zero response from VW I am out - sold my 2019 Sel Prem and off to used Audi Land which is where I came from. Good luck to my brother/sister Touareg owners of past as well.
Peace and quiet reliable driving to you.
1 - 20 of 20 Posts
