Anyone upgraded their car audio with aftermarket parts? Speaker size on doors? Any limitations that they found?
About $800 USYes Ive seen them for sale. Could just be someone selling theirs or on a website, forget where I saw it. How much was the Match system if I may ask
Getting plug & play wiring harness was tight but worked out OK. You just need to remove c/d player and plug in harness. I put the DSP amp under passenger seat.I am looking to upgrade sound as well. Ive installed many systems in my life, but curious as to how hard or what tools are needed to remove that infoentertainment system
Do you have a link or site where you purchased the connector? Also, did you upgrade the factory amp? If so, where was it? Thanks JamesNo aux out. The 52 pin bulkhead connector has to be disconnected so you can plug in the adapter harness. There are about 7 connectors back there including optical depending on what system you have. Everything in the audio system goes thru the c/d player View attachment 1158
Thanks buddy!!I ordered from carfeature.de - Car Hifi Shop in Germany. Part number is PP-AC-92B.
I did not buy the Atlas premium, so no factory amp came with the car. I mounted the new amp under passenger seat with velcro.
