1 - 19 of 19 Posts
My 2021 v6 atlas manual says to use regular octane fuel. Is there any real benefit to using high octabe? Is it still better to use high octane vs regular or is it just a waste? Thanks
Premium Member
Welcome to the forum Yeshia :)
You'll get tons of different opinions on this, you can use the sites user friendly ' Search ' feature for more details(y)
In my opinion stay with the recommenced fuel type during the warranty period. ;)
Per my understanding of octane ratings and I'm not an expert however I have been around for a while.
If the Atlas is rated for 87 there is no benefit to moving to 93 or higher. Higher octane is used to combat predetonation which is more so related to higher compression motors or turbo cars which have high cylinder pressure due to the turbo. 93 octane will burn mostly the same in the Atlas that is rated for 87 and you will see no benefits to your daily driving.
From Google
Octane rating is a measure of a fuel's ability to resist 'knock. ' The octane requirement of an engine varies with compression ratio, geometrical and mechanical considerations, and operating conditions. The higher the octane number, the greater the fuel's resistance to knocking or pinging during combustion.
Been discussed ad-nauseum online here/FB groups/vortex - I will say this and not sure where I put it (could be here if you search) - I posted some timing logs with both 87 and 93 in my Atlas (3.6 VR6). You get less timing correction using premium from my data which will yield some additional power but this will be at the higher-rpm range that most don't use and the extra cost will just not be worth it for 95% of drivers. Perfectly safe using 87 in the Atlas - it's what I use.
Here are my logs - clearly more timing correction on 87 which means you aren't getting the max power available. You will sometimes see the manufacturer handle this when they present power numbers with a * - power figures obtained using premium fuel. Note that for both pulls, variables were as close as I could get them w/r to temp, road, fuel type/station, etc. etc.
87
93
87 but use Top Tier fuel. This will help slow carbon build up on the valves due to it being a GDI engine. Shell, Exxon, BP, Valero and some others use Top Tier Fuel.
Top Tier while certainly the best standard in gas to use, has zero to do with carbon build-up on the backs of the intake valves b/c the fuel never touches them in a DI engine.
I am aware the gasoline doesn't pass over them. The Top Tier Gas helps keep the carbon build up down nonetheless. That's from my reading on it.
How exactly if it doesn't touch them? It's not doing a thing to the valves - only the injectors themselves (a positive!). Folks have debated this issue in online forums and social media for a long time including fuel type, oil quality, "Italian tune ups" and catch cans. None of it will prevent some build-up from happening on the back of the intake valves in a DI engine with no port injection to get some fuel/cleaners on the back of the intake valves. Most modern DI engines are not having issues like the earlier engines had and at worst, if you keep it long enough and have misfires/issues related, you get a walnut blast. I realize some bits online will reference Top Tier as helping but it doesn't....it physically can't.
There is plenty of literature on the subject available on the internet. I encourage you to read it for yourself and formulate your own opinion based on it.
I have and my comments are based on it. For general combustion chamber cleanliness including carbon build-up...yes. Back of intake valves in a DI engine that the fuel never touches...no. Just not much you can do fuel-wise/additive-wise on a DI engine to prevent it from getting some carbon on the backs of the intake values unfortunately but for sure, use Top Tier-branded fuels.
2020 Atlas Cross Sport with Tech
I use what the manufacture says to use. It helps if you have any warranty issues. I used primum gas in my 2013 Toureg it helped get me a little better MPG and smoother running engine
I don't think there is any possible way for octane rating to come into play in warranty discussions or certainly anyway to prove anything.
2021 Atlas Cross Over SEL Premium 3.6L
MPG? I have a 2021 SEL Premium 3.6 4MO etc... I pulled my 1900 pound single axle boat trailer and boat from Cincinnati to upper Door County Wisc. and back last 12 days on vacation. I manually shifted from start to cruise speed of 72-74 MPH in 7th gear (not 8th gear). My mileage on regular fuel, 87, was 13.7 to 14.8 on cruise control. If you use the auto tranny and cruise control with a load the car is constantly down shifting at one gear if not two and your rpm's leap to 3,000 or higher. A gentle accelerator foot and gradually building speed while shifting at 2,000 rpm's worked fine. I had a 10-11 hour drive each way, so using cruise control was a must. On level round, I started up in second gear cause 1st is so low and rpm's are at 2500+ before you can spell go. The four wheel drive and low first gear made pulling the boat/trailer out of the water an easy task. The car was evenly packed and no weight added to the open boat except a few soft item under the bow.
Your thoughts and suggestions are welcome
Here's my question. In Utah, MOST gas stations here have 85 or 91. I'm ASSUMING this is to offset for elevation (4700+ ft). Is this the case?
Just bumping this thread for the same question. I'm in Colorado at 6000 feet. Shopping for an Atlas and considering both the 2.0T and the VR6. I think I would stick with 87 in the 2.0T insofar as the turbo partially compensates for the altitude. But I'm wondering if other high elevation owners use 85 in the naturally aspirated VR6. If so, that could partially offset the cost of the worse mpgs compared to the 2.0T. Dealer rep says it's fine, but I might try to get that in writing for warranty purposes.
With the 2.0T, I would definitely use higher octane. While the ECU can compensate, you lose a lot of power that way. My son has a 2017 Jetta GLI with a 2.0T, and it definitely does better on the 91 octane, even in the higher elevation of Utah.
At elevation it is true that you do not require the same amount of octane to prevent predetonation due to the drop in oxygen concentration at the higher elevation. However, the colder air also makes it more dense in the winter, so I'm not sure where the lines cross between power and predetonation.
I do know that I feel more confident of full power at higher RPMs, which I frequently use when merging onto hilly on-ramps when I am running with 91 octane fuel in my 3.6L V6 as a choice, and not as a requirement. @KarstGeo has shared some remarkable charts showing that higher octane gas changes the ECU tuning, but only at rather high RPMs. If you're not an aggressive driver, and/or do not frequently find yourself flooring the pedal, you probably won't see any benefit, though I can imagine slightly cleaner valves and injectors if the ECU tuning happens less aggressively.
1 - 19 of 19 Posts
